Canon Ir5065 Unusual Image
  • doug
    • Dec 2011
    • 198
    [CQ] Canon Ir5065 Unusual Image
    Please see the following attachment (if you can) this is the first time I have tried to attach and am not sure if I am doing it right.
    Anyway, this is an erratic image and usually jams shortly after. Any help at all would be GREATLY appreciated.
    Doug
  • Brian8506
    • 1664
    Re: Canon Ir5065 Unusual Image
    Check coronas for broken wires or grids and developer cylinder, bearings and spacers
    • Canuck
      Tech Specialist
      • 1713
      Yeah...looks like broken dev spacer....ala np1020....lol
      • doug
        • Dec 2011
        • 198
        Hello There,
        Developing spacers were good, and when it does this make that copy ,it gives an E000100-0001.
        Any other ideas?
        Thank you very much,
        Doug
          • 22999
          The black ovals are a telltale sign of primary charge arcing. I'm afraid I'll have to agree with Brian8506. =^..^=
          • Brian8506
            • 1664
            I'm afraid??
            Doug E100 is a laser problem. Make sure the fan box inside front cover has the pin on the backside that opens the laser shutter
            • doug
              • Dec 2011
              • 198
              Very good I will try a new charge corona unit.
              Thank you both!
              Doug
