IR2525 cannot detect paper at tray 1
  • KM7155
    • Aug 2008
    • 146
    hi guys, appreciate ur input.
    i have 2 canon ir2525, initial problem is one of the ir cannot detect the tray 1, i have swap the switch, sensors, actuator to no avail.
    lastly i swap the board with the working ir, problem still the same.
    now, even the second ir also having the same problem, now i have 2 IRs with tray 1 dead.
  • dan7777
    • Dec 2012
    • 680
    Re: IR2525 cannot detect paper at tray 1
    You need to replace the paper tray feed unit. Sometimes it is the top feed assembly and sometimes the bottom. I don't know what causes it. The feed units are different with different part numbers. I have a lot of these machines.
    • teckat
      • 16083
      does the paper lift up when Cassette 1 is Closed)=== re-seat and inspect the connector for the Paper Pick Up Motor (M3).
      • northernlife
        • Sep 2011
        • 847
        "If no switch is pushed, it is determined as no cassette." Generally when you depress one of the size sensors it should engage the pickup assembly to lift. If no dice, verify that the tray is not broken (i'm assuming the old paper stuck behind the tray has been checked). Might be worthwhile to try a clear all (after backup of course) and see if it comes back. If not then it's all pointing to the dcon
        • teckat
          • 16083
          Time to check I/O signals-
          Sorry, a miss-read on tray detection point.
          • northernlife
            • Sep 2011
            • 847
            service mode > # TEST MODE > 2 sens/sw check
            cst s1 and s2 should be 0 when paper is detected.
            But I'd probably go with just replacing the ppu assy
            • Canuck
              Tech Specialist
              • 1713
              Question...is the issue not seeing the cassette inserted into the cassette 1 slot or ..not seeing PAPER in the cassette 1(machine detects cassette but empty).Your title says cannot detect paper, but your first sentence says cannot detect tray
              • ernesto
                • Oct 2011
                • 430
                Hi
                if the paper size detection error happens with the top 250-sheet cassette. maybe the problem is in the cassette top arm stopper .
                reference FC9-1579-010
                All the best
                • aco.bk
                  • Sep 2012
                  • 130
                  This is my way how to resolve this problem(with cassette) in field...
                  I know it's rude but it works...
                  • 2010mohamed
                    • Oct 2017
                    • 28
                    no its not lift up
                    so whats the proplem
                      Originally posted by 2010mohamed
                      no its not lift up
                      so whats the problem
                      could be the lift motor... could be the activation sensor.
                      have you run motor and sensor check?
                      • 2010mohamed
                        • Oct 2017
                        • 28
                        no .
                        how can i check motor and sensor
                        how can i find lift motor
                        with a photo will be great
                          no .
                          well then break out the manual and run the tests!
                          • teckat
                            • 16083
                            no .
                            (250-sheet 1st cassette model)
                            (550-sheet 1st cassette model)
                            when u remove all paper in tray 1 and select tray 1 to print----do u get message to add paper
                            #TEST MODE
                            Numeral enclosed (in parentheses) denote a numeric keypad key to be pressed
                            ●●FUNCTION Test <(6) FUNCTION TEST>
                            Press the numeric keypad key 6 on the test mode menu to select the function test.
                            Press numeric keypad key #2 = Sensor test = Sensor actuation test.
                            Press numeric keypad key #2 on the FUNCTION TEST menu to select the sensor test.
                            To select a minor item, press the START key.
                            The touch panel (LCD) indications change as the associated sensors turn on and off.
                            CST Cassette check
                            S: Cassette 1 Pickup Sensor (S1)
                            0/Document presence, 1/Document absenc
                            SU: Cassette 1 Paper Sensor (S2)
                            PE: Cassette 1 Paper Level Sensor A (S3)
                            ZA: Cassette 1 Paper Level Sensor B(S4)
                            S1: Cassette Size Detection Switch 1
                            (Width) (SW6)
                            S2: Cassette Size
                            Detection Switch 2 (Length) (SW7)
                            • Gomoox
                              appreciate ur input, you need to replace the paper tray feed unit. Sometimes it is the top of the feed Assembly and sometimes the bottom. I don't know what the cause is. The feed unit is different with different part numbers. I'm trying to share here may be useful. Canon Com/IjSetup
