IR2525 cannot detect paper at tray 1
  • 2010mohamed
    • Oct 2017
    • 28
    #16
    Re: IR2525 cannot detect paper at tray 1
    thanks . hope it will work
    Originally posted by teckat
    (250-sheet 1st cassette model)
    (550-sheet 1st cassette model)
    when u remove all paper in tray 1 and select tray 1 to print----do u get message to add paper
    #TEST MODE
    Numeral enclosed (in parentheses) denote a numeric keypad key to be pressed
    ●●FUNCTION Test <(6) FUNCTION TEST>
    Press the numeric keypad key 6 on the test mode menu to select the function test.
    Press numeric keypad key #2 = Sensor test = Sensor actuation test.
    Press numeric keypad key #2 on the FUNCTION TEST menu to select the sensor test.
    To select a minor item, press the START key.
    The touch panel (LCD) indications change as the associated sensors turn on and off.
    CST Cassette check
    S: Cassette 1 Pickup Sensor (S1)
    0/Document presence, 1/Document absenc
    SU: Cassette 1 Paper Sensor (S2)
    PE: Cassette 1 Paper Level Sensor A (S3)
    ZA: Cassette 1 Paper Level Sensor B(S4)
    S1: Cassette Size Detection Switch 1
    (Width) (SW6)
    S2: Cassette Size
    Detection Switch 2 (Length) (SW7)
