canon S-1 Finsher
  • felix
    • Oct 2011
    • 24
    canon S-1 Finsher
    have S-1 thats ticking me off a little make a copy Tray goes to the bottom stays there paper comes out paper hits the floor tray comes back home.if i leave paper in the tray finisher tray works fine... replaced tray sensor no change ran it without a tray sensor worked fine.
    some bozo had there hands in there as well there is a low voltage wire hooked up to nothing plugs on both ends i have another working finisher that i looked at theres no place for that wire to go.. just crazy.
    i made a small video of what its doing.
    any help would be appreciated.
  • V-P
    • Apr 2011
    • 679
    Re: canon S-1 Finsher
    I think I had smth like that in the past.
    As far as I can remember - we blew air into the sensors (only in the finisher area)
    the cleaning did the trick
    • felix
      • Oct 2011
      • 24
      Thanks V-P...Yeah blew them out as well. had the unit totally apart who ever worked on it before greased crap out of it too cleaned that and removed the dampening pads too.
      i should post a pic with the wire i am talking about too.
        • 23002
        I looks like the "face-up delivery' feature to me. Admittedly odd. =^..^=
        • northernlife
          • Sep 2011
          • 847
          Problem :
          The finisher output tray drives to the bottom when the imageRUNNER is powered on.
          Solution :
          The stack tray shift sensor PI7 was fault and needed to be replaced. The part number for the sensor is WG8-5696-000.
          • felix
            • Oct 2011
            • 24
            sorry black that paper had been run threw a few times.
            was getting tired and pissed at the time... was getting close to bed time..lol
            thanks northernlife
            i will give that a look see..
            • felix
              • Oct 2011
              • 24
              found it thanks for all the help.. watch the home sensor actuator it doesn't come out far enough when the tray is empty for some reason with paper in the tray it seems to make a harder jerk to make it come out further or if i push on the fingers it comes out.. pisser is i cleaned that asm
              seemed to be free.. at least i found it..
              again thank you all for your help
              • northernlife
                • Sep 2011
                • 847
                Haha it happens. Had a 5070 fuser/delivery roller call yesterday that I misplaced the sensor on and kept getting a jam after lol
                  • 16083
                  the notorious stuck flag>>>>/ other finishers have similar issue> different flag location
