Re: Canon IR C3200N Smear on print
Both the upper & lower fuser rollers are rubber & both form flat spots, once that happens you can't doing anything about it.
You can refirb the unit buy simply replacing both rollers & I used to also fit new bearings & bushings at the same time. Then as mentioned update the firmware & I found setting the sleep time to 30 mins helped prolong the fuser life
