Canon IR C3200N Smear on print
    • 8195
    Re: Canon IR C3200N Smear on print
    Both the upper & lower fuser rollers are rubber & both form flat spots, once that happens you can't doing anything about it.
    You can refirb the unit buy simply replacing both rollers & I used to also fit new bearings & bushings at the same time. Then as mentioned update the firmware & I found setting the sleep time to 30 mins helped prolong the fuser life
    • AhaaOkay
      • Mar 2014
      • 24
      Have to put this a bit on the low priority list ..... and focus on our clc 3200 with with imagepass c1 ver. 2
      that doesn't have those issues
        • 16083
        adjective
        Not urgent or of great importance:
