Canon IRC2380i Error code E-350-000
  • SAZ911
    • Mar 2013
    • 193
    [Error Code] Canon IRC2380i Error code E-350-000
    Hi Guys,
    Got a problem with the above mentioned machine. I'm getting and error code of E-350-000. This error does not exist in the manual. The problem is intermittent..
    Has anyone come across this before, and if so how did you get passed it.
    Thanks,
    SAZ911..........
  • copier tech
    • 8138
    Re: Canon IRC2380i Error code E-350-000
    This is to do with the serial number/counter PCB
    Have you replaced any boards recently? Check all boards connections most likely loose conector.
