Canon IR5075
  • DTarry
    • Aug 2025
    [CQ] Canon IR5075
    Machine has random black dots appearing on prints, after machine has run for awhile.
  • northernlife
    • Sep 2011
    • 847
    Re: Canon IR5075
    Leaking developer, old primary charging or failing drum cleaning blade. Could also be cleaning web or pre trans leaking but not too likely, could be wrong though.
    • danno
      • Oct 2010
      • 15
      Re: Canon IR5075
      Could be primary wire set if small dots. Ufr ware qickly on these copiers also.
      • danno
        • Oct 2010
        • 15
        Re: Canon IR5075
        wear quickly. sorry
        • Canuck
          Tech Specialist
          • 1713
          Re: Canon IR5075
          Rewire the primary...change the cleaners too. Common on these models
          • DTarry
            Re: Canon IR5075
            I've changed the wiper blade, Main Corona, Trans/Sep corona, drum and fuser unit all with new parts and still getting random dots mostly on the back side (non-operator) about 2" to 3" in from the back side.
            • northernlife
              • Sep 2011
              • 847
              Re: Canon IR5075
              "Leaking developer, old primary charging or failing drum cleaning blade"
              Developers the next one to change. in 11 years of service, I've never changed a drum in a 5000/5070/5050.
              • DTarry
                Re: Canon IR5075
                This is only the second ASI drum I've had to replace and I've been in the business since 1974. I'm going with the developer idea as that is the only thing I haven't replaced. This unit is in a print shop and the guy runs it like a printing press.
                • kuby
                  • Oct 2007
                  • 1410
                  Re: Canon IR5075
                  Would also check the Shutter seal for the waste toner, FB2-6897, just to be on the safe side. They have been known to leak at times.
                  • Canuck
                    Tech Specialist
                    • 1713
                    Re: Canon IR5075
                    Plugged primary fan filter causes cleaner unit to heat up and form chunks...5000 had same issue....something to look at. Also like mentioned Upper fuser rolls wear thru at around 300k. Also the catch pans on the bottom of the process unit gather toner in them....sep claws mounted to them...seen them sprinkle toner
