Canon iR Advance C5045 fuser knocking noise
  • apollo
    • Mar 2008
    • 191
    [Misc] Canon iR Advance C5045 fuser knocking noise
    Hi Guys
    Got the fuser making knocking noise, as if cannot find the home position.
    I have replaced fuser fixing film unit complete wiring loom all sensors on fuser.
    cams are fine.
    also tested on another copier doing the same fault
    works sometimes for few minutes than knocking noise starts keeps rotating.
    lost for ideas now.
    if any one had similar issues any help would be much appreciated.
    Many thanks in advance
  • northernlife
    • Sep 2011
    • 847
    Re: Canon iR Advance C5045 fuser knocking noise
    you have to take apart all the gears in the fixing assembly and clean off all the grease with alcohol.
    • apollo
      • Mar 2008
      • 191
      Hi
      striped all gears look clean but been well cleaned
      • V-P
        • Apr 2011
        • 679
        Are you using an OEM fixing film unit or compatible?
        • Austec
          Originally posted by apollo
          Hi Guys
          cams are fine.
          lost for ideas now.
          At the rear of the fuser assembly where you cleaned the grease off those gears, there is a cam shaft with a leaf spring assembly. Remove the leafspring (1 cover and 1 screw iirc) and bend it in to put more pressure on the cam to stop it.
          That should fix it. But do make sure you remove all the grease from the cam etc.
          • apollo
            • Mar 2008
            • 191
            Hi
            yes OEM fixing film complete assembly FM3-5951-010 and installed new leaf spring.
            but will try and bend spring leaf and strip gears again and clean.
            will update
            thanks
            • apollo
              • Mar 2008
              • 191
              Hi
              all gears stripped and cleaned off grease., specially the one where the leaf spring rest on.
              leaf spring slightly bend to give more pressure and noise is gone.
              thanks everyone for your input.
              thanks
