Canon ir3300 wont pick up paper from tray 1
  • jzheld
    • Sep 2010
    • 162
    Already changed the rollers, still wouldn't pick it up, interchage the roller with tray 2, still the same, tray 2 works fine no matter what rollers are in, can't understand what does it want. Any ideas? using regular letter size paper 20lb.
    thank you
    John
  • copier tech
    • 8169
    Re: Canon ir3300 wont pick up paper from tray 1
    Could be a number of pastic parts on this old model failing seen this loads of times.
    If you dont want to order a new pick up assy (expensive) you'll need to strip it down & find out what part has failed. Most likely a cam or spring mount has snapped. If Canon still supply the deck parts it's usually a cheap repair but takes time to strip down etc.
    Still a good model this they'll run on for years.
    • jzheld
      • Sep 2010
      • 162
      Thank you, will strip the machine down over the weekend and see what is wrong.
      • Canuck
        Tech Specialist
        • 1713
        Probably chipped lifter gear and knife. Pain in the butt to replace parts. Send in a sales rep. If you rip that pickup assembly apart it might not work when you put it back together...
