A Competing IP Address was found on the Network
  • Rakesh
    • May 2012
    • 72
    [Misc] A Competing IP Address was found on the Network
    Hi All
    I'm working on a IR Adv C2220 that is giving a message on screen 'A Competing IP Address was found on the Network' after installed New Main Controller PCB 1.
    so i can't able to connect copier in LAN. and Printing working fine from USB.
    If anyone can help I would greatly appreciate it.
    Thank you
    View Life As A Continuous Learning Experience...
    • 23009
    Re: A Competing IP Address was found on the Network
    The machine is telling you that there's a dupe (a duplicate IP address on the network). You have two choices:
    1) you can figure out what the other device is trying to share the IP, and change the address. A utility like NetScan will get the MAC address of the device. From the MAC address you can determine the manufacturer of the device (the first 6 digits of the MAC address identify the manufacturer). Here's where it get's more difficult. There may be hundreds of Dell PC's.
    2) you can change the IP of the MFP. You'll also have to change the port on the print drivers to match.
    Typically, the second choice is a whole lot easier to execute. =^..^=
    • vamoursly
      • Sep 2011
      • 273
      Far easier to get the MAC address of your copier, go to the DHCP server and reserve an address, then put your copier on that static ip address.
      Job done, or get the IT support dept to sort it out for you
      V
      • Rakesh
        • May 2012
        • 72
        found the solution for this problem. see attached service bulletin for more information.
        • Rachid.Akli
          • Oct 2011
          • 595
          Hello,
          Thanks for sharing.
          Rachid.
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • Brian8506
            • 1665
            So I have the same message on a C2225 that's less than a year old. Customer can print to it, I can ping it but it won't scan to folder. Haven't replaced anything. First service call. Any thoughts?
            • teckat
              • 16083
              TCP/IPv4 Settings
              A competing IP address was found on the network.
              Cause
              The same IPv4 address that is set to this machine already exists on the same network.
              Remedy
              See "TCP/IPv4 Settings" to change the IP address of this machine not to be duplicated with the IP addresses which are set to the other devices.
              Or*****
              https://youtu.be/kJcuFwVMzH47
              • Mannu6003
                • Nov 2019
                • 2
                I have canon imagerunner advance 400 and i got massage ' competating ip address was found on the network' can anyone help about this issue please i already tryed all clear machine but still same issue..plz reply me as soon as possible...
                  did you even READ the whole thread... many suggestions and pdf's to follow
                  usually we consider a thread DEAD after 2+ years from last comment.
