IR3025 1 Cassete cant lift up.....
  • netbaba2000
    • Jul 2014
    • 21
    [Misc] IR3025 1 Cassete cant lift up.....
    Hi Copytech
    My ir3025 1st cassette cant lift up. Try with 100 paper in cassette again 200 to 500 pager but still same problem.
    please help me
    thanks
    Prashant
  • lilleputte
    • Jan 2013
    • 153
    Re: IR3025 1 Cassete cant lift up.....
    Hi
    Sounds like the cassette lift not working. Unscrew the back cover and check it
    /Lilleputte
    • netbaba2000
      • Jul 2014
      • 21
      Hi Thax for Reply.
      when i insert the 1 cassette in machine there is some lifting sound ( tik tik tik tik ) came out. but no cassette detect on screen.
      i think motor is working. gear is ok.
      Prashant
      • teckat
        • 16083
        Originally posted by netbaba2000
        Hi Thax for Reply.
        Prashant
        The lifters would lift but the cassette would be grayed out and would not able to be used.
        so your panel does not show cassette ???
        Try Clearing Common Copy Settings in Additional Function
        lifting takes place all the way up > until paper present is detected.> if no paper is present at sensor arm angle signal > u receive "add paper"
        does lifting stop ?
        u see add paper message ?
        • copier tech
          • 8195
          Very common fault on this series.
          After you close the cassette & the ticking stops, open the tray, does the lifter plate drop down? if yes then it's a sensor fault, if the lifter plate doesn't lift then it's mechanical.
          You can strip the C1 feed unit, usually a worn gear or cam, but personally I simply replace the complete unit, they're not too expensive.
