Canon IR3570
  • sniper2g8
    • Jan 2013
    • 117
    [Jamming] Canon IR3570
    Initially the machine was jamming and showing error code E00007-000 and I changed the fuser sleeve and the lower roller. the code has been cleared but A4 and A3 sheet always keep jamming only A4R print fine.
    please help.......
  • Blizzoo
    • Aug 2013
    • 608
    Re: Canon IR3570
    I belive that the film sleeve doesn't turn in right speed,maybe grease problem.Are the pressure bushings worn/"dusting"?
    • sniper2g8
      • Jan 2013
      • 117
      Re: Canon IR3570
      Please can I have a look of the pressure bushing
      • sniper2g8
        • Jan 2013
        • 117
        Re: Canon IR3570
        The jamming code 0108
        • Brian8506
          • 1665
          Re: Canon IR3570
          Did you clean the old grease off and put new "good" grease on the heater element? Are the copies blurry? If so, that could be a sign of bad or no grease. Also paper moisture this time of year causes lots of problems. Paper runs better in the R direction when humidity is high
          • teckat
            • 16083
            Re: Canon IR3570
            0108 code is a delay jam to the No.1 delivery sensor, PS14.
            Check the operation of the Fixing delivery reverse flapper
            checked delivery shaft ?
            coping or printing or both ?
            is this from any paper source?
            • sniper2g8
              • Jan 2013
              • 117
              Re: Canon IR3570
              I cleaned the old grease out and put new good grease
              the R direction only jam for the first two copies when the printer is turned on but the A3 always keep jamming
              • Brian8506
                • 1665
                Re: Canon IR3570
                Black damper pads for delivery flapper probably worn and sticky. Those will cause 0108 jam
                • teckat
                  • 16083
                  Re: Canon IR3570
                  as noted by Brian8506
                  DAMPER PAD LOCATIONS
