IR 2016 wrinkled paper
  • mido
    • Nov 2011
    • 177
    [CQ] IR 2016 wrinkled paper
    Hi,
    Please I need help about wrinkled paper in IR2016. it runs correctly without jaming, but crinkled in the middle of the copy .
    Regards
  • ernesto
    • Oct 2011
    • 430
    Re: IR 2016 wrinkled paper
    Originally posted by mido
    Hi,
    Regards
    Hi
    Maybe there is dirty on the guide before the roller pressure.........you can try to clean it.
    ALL THE BEST
    • mido
      • Nov 2011
      • 177
      thank you
      the guide cleaned .nothing exist in the way of the paper.
      • skibum
        Independent Service Tech
        • 231
        1.) It could be the paper supply. If it is humid, damp outside (machine near outside or window open) or you have not been printing daily the paper can take on humidity and then when heated in the machine the paper changes shape under the fuser's heat.
        2.) Check the fuser rollers and bushing/bearing to the fuser rollers for damage (the press roller or lower fuser roller) and the pressure between fuser rollers, called nip pressure. The nip pressure is usually 8-10mm approx equal from one side to the other side with a +/- 1mm in the middle for an approx. spec.
        Good luck!
