Canon IR 3300 Error Code No. E0000-000
  • Mohammedirfan
    • Oct 2013
    • 12
    [Error Code] Canon IR 3300 Error Code No. E0000-000
    Hi this is irfan i have canon ir 3300 last 2 day it show this error code repeat when i clear the error code the comes back that error code. i replaced fuser fixing film and pressure roller Please help me.
  • teckat
    • 16083
    Re: Canon IR 3300 Error Code No. E0000-000
    1. Connector
    Is the connector of the fixing assembly connected ?
    a. main power supply PCB (J8) <-> relay connector <-> heater
    b. DC controller PCB (J320) <-> relay connector <-> thermistor
    NO: Connect the connector.
    2. Fixing film unit (thermistor)Main power supply PCB, DC controller PCB
    Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB?
    Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
    Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
    YES: The heater drive power supply is faulty. Replace the main power supply PCB.
    NO: The thermistor control mechanism is faulty. Replace the DC controller PCB.
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      I wouldn't waste a lot of time on diagnosing that old fuser when it can be replaced very cheaply. Just get a rebuilt fuser from Fusion Image Technologies and be done with the issue. Teckat posted about them here ages ago and they are a good resource for affordable ready to go Canon fusers.
      • copier tech
        • 8172
        If you have replaced the fixing film, assy from Canon not just the film???
        Also check the condition of the heat sink roller, however this is an old machine now, personally if my customers don't want to upgrade simply show them how to reset the error as I do.
        • blazebusiness
          • 1257
          He indicated that the error cannot be reset at all. He resets the code and it comes right back. Best option now replace the whole fuser(or just the fixing film assembly as you correctly suggested)
          • copier tech
            • 8172
            With his poor English I understood him to mean the error happened twice after he cleared it, however I that error E000 is related to the fixing film assy.
            • Brian8506
              • 1665
              Sounds to me like he replaced the film only. Problem wouldn't be the film but the element. Replace upper film assembly or the entire fuser unit.
              • ernesto
                • Oct 2011
                • 430
                Hi,
                You can try to adjust this: * Additional Functions > Common Settings > Energy Consumption in Sleep Mode >
                Low (Default)→High
                All the best
                • northernlife
                  • Sep 2011
                  • 847
                  If the entire film has been replaced and still getting an e000 I've seen relay 1 on the main ps pcb no longer function. It is triggered by 5V from the dcon.
                  • Mohammedirfan
                    • Oct 2013
                    • 12
                    Now i replace the fixing film assembly but error still comes back, when i try clear the error, the keys are not working. what can i do?
                    • northernlife
                      • Sep 2011
                      • 847
                      you can't get into service mode with add functions > 2+8 > add functions?
                      • JAYAN PRINTO
                        Replace the heating element
                        • Mohammedirfan
                          • Oct 2013
                          • 12
                          Now i am replace the entire fixing film assembly, now showing E000-000 error was gone, but now i have problem with paper jam between fixing unit and delivery unit. when i made a copy single side that come easily without any problem. When i made a duplex then paper jam in above said area, what i do now? please help me.
                          • teckat
                            • 16083
                            DUPLEX JAME CODE
                            • Mohammedirfan
                              • Oct 2013
                              • 12
                              Originally posted by teckat
                              DUPLEX JAME CODE
                              there is no error code just showing Paper jam
