problem with scanner/copier function
  • ttques
    • Jun 2025
    [Misc] problem with scanner/copier function
    what could be the problem with a canon imageclass mf 8080cw multifunction printer that stopped making copies, and scanning. I check the scanning mechanics ie. light and scan bar movement all are functioning correctly. There doesn't seem to be any blockage the printer is clean. Just wondering if it's a board problem, or the scanner assembly?
    • 22997
    Re: problem with scanner/copier function
    Do you get an error message?
    Does the paper jam?
    Does the scanner attempt to move?
    We'll need just a tiny bit more information please. =^..^=
    • ttques
      No Error Message, No Paper Jams, Scanning bar lights up and moves as designed.
      When I make a copy with text either from the manual feed or the flatbed, the paper feeds comes out blank (white sheet).
      When I make a copy with the lid up, I am expecting a black page, but instead I get a blank (white sheet)..
      I believe it is possibly a bad board or even worse a bad Scanner assembly just don't know for sure.
        • 22997
        Are there any internal reports or demo pages you can print from the user menu? Can you print to it? If there is image for any of the previous, it could be a scanner problem.
        Another thing you can do is emergency stop the machine with the paper at the drum (open a door at the right moment, it may take a few tries). Is there a developed image on the drum, but not on the paper? If yes, it's a transfer issue. =^..^=
        • teckat
          • 16083
          Is the drum functioning (rotation)
