np 6035
  • vj200729
    print mate
    • 81
    np 6035
    when a 6035 swtches on scaneer jerks on moving forward and this is occasionally.i checked scanner on swithed off condition it was freely moving.anybody can sujest any solution.
    • 23008
    Behind the toner hopper there is a scanner drive drum with two set screws. One or both of the set screws can back out, intermittently hitting a black plastic shroud that covers the scanner drive and keeps the toner out of it.
    There is an identical scanner drive drum on the back but it is not shrouded, so the set screw doesn't have anything nearby to hit.
    A dry scanner rail can produce some unexpected resuts also. Such as: Noise as scanner vibrates, slams into left frame. "99" displayed, logic lockup. E202 stored, not displayed. Possible erratic registration, thick black line at lead edge. Blurry copies ~850% enlarged in feed direction only. Misfeeds (jam code 0700).
