IRCA2020 E020-1360 & E020-1260 error
  • copier tech
    • 8138
    [Error Code] IRCA2020 E020-1360 & E020-1260 error
    Hi guys, I have to attend the above m/c after my colleague attended, he relpaced all the drums but the errors remain. Not seen this error myself before, anyone had this?
  • teckat
    • 16083
    Re: IRCA2020 E020-1360 & E020-1260 error
    E020-1360 is indicating an abnormal patch reading value is detected for BLACK
    patch sensor, laser dust glass were cleaned
    • copier tech
      • 8138
      He is a new tech so maybe not cleaned the laser glass, hopefully that's all it is! however he's also reporting that there's also a E020-1260 error, related to cyan?
      • SAZ911
        • Mar 2013
        • 193
        Hi Copier Tech,
        It could be as simple as the laser needing cleaning as these machines run very dirty after a while if not serviced. Also i have had the shutter levers and locks break in my machines due the very strong springs springs used to tension the locks and levers.
        Hope the below info helps......
        In My IRAC2020 Troubleshoot guide if found the below info:
        Good luck......
        SAZ911..........
        • copier tech
          • 8138
          Thanks for the info guys, just been in, cleaned the laser & patch sensors, ran auto grad m/c is now fine.
          Funny system having a shutter over the lens, had to read the manual to work out how to clean the laser glass!
            I find it easier to remove the laser than use that laser cleaning arm.
            Dont know why he removes the low voltage pcb though
