IR 3245i code 000611-000
  • bernyb
    • 42
    [Error Code] IR 3245i code 000611-000
    Hi,
    Does anyone know what this error code refers to? I seem to find different answers to this code. Thanks
  • copier tech
    • 8195
    Re: IR 3245i code 000611-000
    Did you see this thread:
    http://www.copytechnet.com/forums/ca...611-000-a.html
    • bernyb
      • 42
      Thanks for the help copier tech. I looked at the link you referred to and tried what it said to do. Which had to do entering service mode and then go to Copier>Function>System, Changing the value of CHK-Type to a 1 and press ok then HD clear and press ok. Repeat through 6. All reported back okay except CHK-Type 4 and 6 and they reported back as NG. Error code still there. Would you happen to know what CHK-Type 4 and 6 are and where to go on the next step? Thanks.
