IRC2380 Poor Black Solids
    • 8103
    [CQ] IRC2380 Poor Black Solids
    Got an issue with an irc2380, basically the black prints are feint, I have attached a PG10 sample, the blacks looks gray, YMC all have perfect solids.
    So far I have replaced the black drum & ITB, cleaned the laser glass (thoughly) & cleaned all contacts, this initally improved but the issue soon returned.
    The DENS level is fine so I don't feel it's a lack of toner issue, any ideas!?
  • ernesto
    • Oct 2011
    • 430
    Re: IRC2380 Poor Black Solids
    [ATTACH=CONFIG]26652[/ATTACH]
    what about % drum black?
    • Nutstar
      • Mar 2011
      • 110
      drum.
      next!
        • 8103
        What part of my sentence above "So far I have replaced the black drum" did you not understand!?
        • MunsterTech
          • Sep 2014
          • 377
          is it OEM or compatible toner?
          • jrgf67
            • Feb 2010
            • 37
              • 8103
              Yes OEM toner & drum
              • Nutstar
                • Mar 2011
                • 110
                apologies, I missed it at the start.
                well it certainly presents as a drum issue, its not the laser since the others are ok, did you clean the contacts for the drum unit?
                also have you tried alternative paper stock? (have had some random issues with poor quality paper in the past).
                also perform the autograd and colour mismatch corrections
                • Nutstar
                  • Mar 2011
                  • 110
                  also, side note, what do the PG5's for each colour look like? are they ok on colours and not on black, any variance in gradation on the colours?
                  • ernesto
                    • Oct 2011
                    • 430
                    Does anyone know the solution?
                    • misserable old git
                      • Aug 2014
                      • 19
                      Try the following....
                      service mode>copier>function>cleaning>TNR-COAT
                      This will put a coating of yellow toner onto the secondary transfer roller that will Improve transfer.
                        • 2621
                        Sometimes you need to take off the laser lid and clean inside.
                          • Aug 2014
                          • 19
                          try the following...
                          this will put a coating of yellow toner on the secondary transfer roller that will improve transfer.
                          • canon33
                            • Jun 2014
                            • 65
                            +1 on this. Each color has its own laser. I have removed and cleaNed the inside mirrors on quite a few. Have u looked at color balance settings under settings/registration? I would clear that out and see if factory default looks better.
                            Good luck
                            • DAG COPIERS & COMPUTERS
                              • Oct 2010
                              • 860
                              Dear copier tech & ALL,
                              Thank you for your post. The step you took in cleaning the laser glass, among others, was a step in the right direction and that's why you were able to register some initial success although briefly. Whenever I'm confronted with a problem of this type be it in a canon or HP machines, I have done nothing else to solve the problem other than CLEANING, CLEANING & CLEANING thoroughly WELL the LASER EXPOSURE UNIT! And each time I do that it has worked for me very well.
                              This is a pragmatic & simple solution with one PARAMOUNT condition though: You have to be very DILIGENT & PATIENT in doing the cleaning, paying great attention to detail,and being always ALERT that you are handling a precision part, any mistake in a shift in the position of the mirror or lens can render the unit useless, since the laser light path will be deviated from its prescribed direction!
                              Now here we go:
                              1)- Remove the laser unit in charge of printing the black color from the machine; take off the lid and the vertical cover to expose the corrective lens and motor, from the lens unit.
                              2)-Using a lint free cotton swab(similar to one you use to clean ears) or a piece of lint free rug, clean, clean & clean thoroughly well, the following components of the laser unit:
                              -The GUIDE MIRROR: Since it is responsible for directing the laser beam in the direction of the drum.
                              -The CORRECTIVE LENS: Since it is the one which corrects the displacement of the laser light coming from the guide mirror, in the main scan direction.
                              -The POLYGON Mirror.
                              -The Dust Proof blocking Glass.
                              Note:You may slightly wet the cotton swab or rug in clean water to clean the mirrors, especially the ends to remove some of the 'stubborn stains'. Then wipe again with a dry rug or swab.
                              You may repeat this cleaning operation until you are completely satisfied with cleanliness.
                              -Put back the laser unit covers and reinstall back into the machine; clean the vicinity!
                              NEXT:Open and clean the optics inside the scanning unit of the machine to rid of condensation and dirt; don't forget to clean the Copy board glass and stream reading glass as well.
                              -Finally, Stresses(both physical, thermal & electrical) to which the machine has been subjected over time has caused a shift in some vital parameters of the various components responsible for image formation in the machine, resulting into deterioration in Image Quality! Therefore, perform an AUTO GRADATION Adjustment(in user mode) to adjust the Toner density; in the process, this function also corrects the laser output, allowing ideal image gradation characteristics to be obtained!
                              It may be a tedious process but cheaper than replacing a laser unit.
                              Enjoy a Superior copy quality!!!
