MF4140
  • akm
    • Sep 2012
    • 155
    [Error Code] MF4140
    Dear/ CopyTechTeam
    Please i want your help to solve the error e225 appears in the screen of MF4140
    thanks
    akm
  • ernesto
    • Oct 2011
    • 430
    Re: MF4140
    Originally posted by akm
    Dear/ CopyTechTeam
    thanks
    akm
    Hi,
    May be the lamp is a fault......
    All the best
    • akm
      • Sep 2012
      • 155
      Re: MF4140
      Originally posted by ernesto
      Hi,
      All the best
      I changed the CIS but the error still appears
      • teckat
        • 16083
        Re: MF4140
        could have a damaged cable or connector
        • akm
          • Sep 2012
          • 155
          Re: MF4140
          I checked the flat cable and connectors , they are working
          • Blizzoo
            • Aug 2013
            • 610
            Re: MF4140
            Yes,they may be fine when metered but when flex cable bent sometimes fail to conduct.
            Take a good clean to white refference underneath glass and test.
            Had once a bad CIS motor leading to this error.
            • teckat
              • 16083
              Re: MF4140
              U could also have a voltage supply issue or improper ground V from outlet
              • ncbabak
                • Apr 2014
                • 43
                Re: MF4140
                Dear/ CopyTechTeam
                thanks
                akm
                Hi , If you changed the CIS and cable but the error still appears,You must Use FirmwareUpdateTool .
                • copier tech
                  • 8193
                  Re: MF4140
                  I had this before, theres a CIS setup you need to run in service mode, you don't need to replace the CIS, check the service manual
