what "pre transfer " uses for ?
  • vins
    • Oct 2013
    • 18
    my ir6020 is not equipped with this part.. what the effect to my machine if this part not installed ? thank you
  • teckat
    • 16083
    Re: what "pre transfer " uses for ?
    [ATTACH=CONFIG]26824[/ATTACH]
    Can cause Light Prints (including in solid black area) (or overall )
    AC constant voltage control: fuzzy by environment sensor
    DC constant current control: on/off control only
      I was told on a Toshiba training course that pre transfer removes any static charges from the paper prior to the copy process.
      • teckat
        • 16083
        pre-transfer charging control system:
        1. controlling the constant current level of the DC bias
        2. controlling the fixed voltage level of the AC bias
        3. controlling the output to suit the environment (fuzzy control)/The pre-transfer charging current is optimized to suit the environment (i.e., reading of the environment sensor):
        JUST PURCHASE ONE
        • Canuck
          Tech Specialist
          • 1713
          Simply speaking...the pre-transfer loosens up the toner "latent" image on the drum before it is transferred to the paper by the transfer corona/ETB assembly. The AC component of it equalizes the charge of the image before transfer, just like separation AC removes charge on paper before fusing
            • 23009
            From a practical point of view, the blocks probably shorted out, and the tech didn't have the part on-hand. So he removed the shorted unit, and left it that way. I can't explain why he would have left it that way. =^..^=
            • ZOOTECH
              Senior member of CRS
              • 3375
              His name was probably 'Bob'.
              • vins
                • Oct 2013
                • 18
                thankyou for your replies. and i want to ask, why my machine only gives about 15,000 sheets (for 1 kilogram toner) yields (almost only text ? what settings that i must check ?
                • teckat
                  • 16083
                  Canon standard for testing & posting toner usage\coverage yield volume is _
                  5%>6% text coverage on letter size.
                  • ernesto
                    • Oct 2011
                    • 430
                    Hi,
                    Do you know the best way to clean the wire of the pretansfer unit ? it can be cleanned with alcohol ?
                    All the best
                    • vins
                      • Oct 2013
                      • 18
                      i compare with another machine (iR5070) 5070 can make 25,000 copies. either 6020 and 5070 machine almost i use for copying text
                      • teckat
                        • 16083
                        Estimated average values in the field, based on data from supplier.
                        Data is subject to change depending upon many factors including, without limitation, monthly copy volume, environment, type of image printed and customer handling of the equipment.
                        imageRUNNER 5070
                        Estimated Toner Yield: 45,000 Images (at 6% Letter Coverage)
                        Canon OEM>GPR-17 Black Toner 0279B003AA--(Dry Volume: 2,000 g)
                        imageRUNNER 5020/6020
                        Estimated Toner Yield:: 33,000 Images (at 6% Letter Coverage)
                        Canon OEM>GPR-4 Black Toner 4234A003AA--(Dry Volume: 1,650g)
                        Even if box has Canon OEM > no guarantee it is ( counterfeit products & packaging are worldwide )
                        • vins
                          • Oct 2013
                          • 18
                          imageRUNNER 5070
                          regarding that data .. 1000 g dry volume of toner >> 5070 = 22,500 images, and 6020 = 20,000 images.
                          • teckat
                            • 16083
                            means nothing > it's just called ESTIMATE > take it with a "Grain of Salt"=to view something with skepticism, or to not take it literally.
                            • nmfaxman
                              • 1702
                              5% fill is the equivalent to one paragraph double spaced.
                              I tell customers to expect have the yield or more if graphics are in document.
