canon IR1023
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    canon IR1023
    Customer said they are having quality issues, lines
    etc. They never had a drum so I was going to order
    that. Anything else besides drum and fuser that
    would cause quality issues? Any other PM items I
    should get when I order drum?
    Thanks in advance
  • bipc
    • Sep 2009
    • 194
    Re: canon IR1023
    go for the drum only since they never changed it before, that line usually has developing cylinder problems also, but for now the drum is probably enough
    Life is a learning continuum...
    • copyman
      Owner / Technician
      • Sep 2005
      • 4700
      Re: canon IR1023
      Thanks for the reply. Do I need to reset or calibrate anything after replacing the drum?
      • Brian8506
        • 1664
        Re: canon IR1023
        No
        • dan7777
          • Dec 2012
          • 680
          Re: canon IR1023
          I agree. Usually that is the most replaced part. Make sure optics are clean.
