Questions about using Com10 Envelopes in the C5000 Series , Which are the best?
  • Canon345
    • Jul 2025
    [CQ] Questions about using Com10 Envelopes in the C5000 Series , Which are the best?
    OK so far the machine has issues with envelopes, com10. What has been the best formula for you experts to use? Is the Manual feed tray an option or should customer be sold envelope option tray. If so, is the tray worth the upgrade in your opinion. Will the staples stuff not wrinkle? Please, your thoughts, experience. Thank you.
  • teckat
    • 16083
    Re: Questions about using Com10 Envelopes in the C5000 Series , Which are the best?
    If the flap and trail edge wrinkle. _?
    Level 1
    COPIER > OPTION > FEED-SW > EVLP-SPD
    There are two settings:
    0 = 1/2 Speed (default)
    1 = 1/1 SpeedWhen loading envelopes on the
    imageRUNNER ADVANCE C5000 Series, the position that the envelopes are loaded can pose wrinkling problems due to the position of the flapper.
    It has been tested that if the envelope is turned 180 degrees, it has produced better results with decrease wrinkling and jams.
    This has been proven as a workaround with the Envelope Feed Tray Assembly that mounts in Cassette 2.
    Also you can change the following settings in Service Mode
    Copier > Option > Feed-Sw > EVLP-SPD and EVLP-FS
    These settings have proven to resolve wrinkling and misfeeding issues.
    NOTE: Please be aware that the only remedy to envelope issues is to try other types of envelopes. This has been a proven remedy in the field.
    • Canon345
      Thank you. I will post my exact findings. I have a test machine with an envelope option. Will see customer machine soon.
      • Canon345
        Well the customer was getting smashed crinkle at the end of the Env. Slammed in some 24 lb Staples Env with the staples labeled adhesive strip. Not the lightweight ones. Worked a treat on default settings!
