Paper sensor is not work
  • selva
    • Feb 2012
    • 16
    [CQ] Paper sensor is not work
    Hello, My canon ir105+ copier machine paper tray load. But control panel paper selection display blinking. Why this problem.
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: Paper sensor is not work
    Hello,
    It is hard to explain the reason of your issue. I'll do my best to help you.
    I guess that the problem is with tray number 1( the most used one). When the tray is pushed inside the machine, there is a part that will make the pick-up rollers fall down. In your case, the pick-up rollers with the paper sensors axis are not going down enough.
    Pages de ir8500-sm.pdf
    Rachid.
    "Find a job you love and youโ€™ll never have to work a day in your life." Nagy's father
