Canon IR 3380i Error Code E000067-0101
  • Joeavisco
    • Jun 2025
    [Error Code] Canon IR 3380i Error Code E000067-0101
    When all was well with my print quality thanks to you guys, my IR3380i is just showing E000067-0101 and asking me to shut down the machine which i have done the whole day yesterday. i urgently need help from you guys to finish an urgent printing assignment.
    Thanks in advance.
    Joeavisco
  • V-P
    • Apr 2011
    • 679
    Re: Canon IR 3380i Error Code E000067-0101
    This error is :
    High voltage-related error (Primary transfer)
    The first detected current of primary transfer ATVC is the threshold or more.
    Check on the primary transfer roller spring, Clean the position
    where the primary transfer roller contacts, Replace the primary
    transfer roller, Replace the drum unit
    Check a value of COPIER> DISPLAY> MISC> DRM-LIFE,
    and replace the drum unit if the value is near 100 because the
    drum may have reached its life expectancy.
    In other words one of the drums is probably gone.
    Hope this helps...
    • Canon345
      Generic Drums ? thats the kinda thing we would see on previous IR B/W machines with a generic drum. Generic drums are out there for the C3000 series.
      • kei9tha
        • Feb 2014
        • 88
        had the same code on same machine. i had to replace all the drums because their counts were all over 100%. fixed the issue.
        • canon33
          • Jun 2014
          • 65
          This is a common problem especially after replacing drum . Make sure software is up to the latest and greatest. Canon released new software to fix this. If it's up to date and not fixed then u r gonna need to replace itb assy.
          • teckat
            • 16083
            Thanks in advance.
            Joeavisco
            ??> are u a tech
            If ITB is old & over percentage on Black Drum-
            I recommend to replace the ITB Assembly & all DRUMS at same time/
            • copier tech
              • 8133
              Yeah I agree, seeing this error a lot now. New ITB & black drum usually sorts it.
