Life of drums black in the iRADVC 20/22xx series.
  • JPiek
    • Oct 2014
    • 435
    #16
    Re: Life of drums black in the iRADVC 20/22xx series.
    What kind of setting are these ? I'm interested.....
    Johan
    • copier tech
      • 8172
      #17
      This is what I do
      IRA C2030 Drum Replacement
      (1) Go In service mode change > Copier / Option / Display SW / ITB-DSP set to =1
      (2) Go into setting and registration / adjust maintenance / ITB-drum
      (3) Then do a full auto gradation
      1. Specify the colour with which ghost occurs by visual check
      2.Increase the level of Upstream DC bias by 1 (L2) COPIER>ADJUST>HV-PRI>USUB-xDC
      3.If the trace of Upstream Brush has not disappeared, decrease the level of Upstream DC bias by 1
      4. Decrease the amount of toner deposit (L2) COPIER>OPTION>IMG-MNCON>TNR-DWN 5. If the issue still persists, replace the Drum Unit of the specific colour 6. Return the service mode setting value to the default
      • vamoursly
        • Sep 2011
        • 273
        #18
        Which Canon Tech - does not work, every single Canon Dealer I know are dumping these machines
        • copier tech
          • 8172
          #19
          I have had some sucsess with theese settings, worth a try nothing to loose!
          Shame Canon wont redesign theese drums, not a bad machine apart from this poor drum life issue.
          • MFPTech
            • 486
            #20
            The settings are included with the new type of ITB
            • ernesto
              • Oct 2011
              • 430
              #21
              does anyone know if we replace blade iradv2020 it solves the problem?
              All the best
              • copier tech
                • 8172
                #22
                There is no blade in the drums on that model, it uses charge brush to clean the drum, so no dont waste your money!
                • ernesto
                  • Oct 2011
                  • 430
                  #23
                  Sorry about the name can you see the picture on the right side...?
                  • Canuck
                    Tech Specialist
                    • 1713
                    #24
                    I see them run from 65% to 150%. Cheap design on units. Uses pulverized toner ..cheaper toner to manufacture...with brushes to charge residual toner to be attracted back to dev cylinder. The older IRC3200 family used brushes with polymerized toner. Worked very good...them drum units ran to 200% alot of the time. Never get them yields on Advanced 2020
                    • dragstar
                      • Aug 2013
                      • 5
                      #25
                      This model is garbage...
