Canon Np 6050 Jam at right door at power on
  • mdm7266
    • Dec 2007
    • 99
    Problem "jam at right door remove jam" its pointing on the middle door.
    Replaced ps30, ps27, ps36 still jam at power on.
    Do pick-up assembly can cause jam indication at power-on on the copier? it has many sensors.
    No stack piece of paper.
  • josh kisoso
    Re: Canon Np 6050 Jam at right door at power on
    /www.youtube.com/watch?v=lCA71NSaz5A
    • teckat
      • 16083
      17 sensors
      u never look at the obvious jam location in this piece of junk printer
      Check the spring tension of all sensor flags, and add a wrap if necessary./ KNOWN ISSUE WITH FLAGS
      another issue in this series is the wiring.
      For the 010C jam code, it's typically the fuser drive clutch
      I personally would remove the Finisher/
      then gut the printer to physically look for any PAPER FRAGMENTS that may be lodged inside connections on Frame Side & on all Removed Assembly s
      PAPER FRAGMENTS in connections// known issue on power on Jams for this NP SERIES
        • 23007
        Yes! How about a jam code? =^..^=
        • mdm7266
          • Dec 2007
          • 99
          Here is the jam code
          B_JAM0: 0208 010A 010A
          B_JAM3: 010A 010A 010C
          B_JAM6: 010C 010D 010C
          B_ALRM: 0001
          Replaced wiring from dc controller
          Replaced pick-up assembly
          replaced unit 1 assembly
          checked flags/springs of sensors -ok
          still same jam on middle right door at power on
          if i'm not mistaken, 01 and 0A is for pS24 and ps23 sensors
            • 23007
            Misfeeds (jam code 010C, 020C, 010A), accordions in the claw area. Also noise when driving. Flat spots on the lower fuser roller make the drive difficult to turn, causing the fuser drive clutch to slip and damaging gear 31T. Replace the lower fuser roller (FB3-8102-000) and gear 31T (FS6-0116-020). Clean and grease the fuser drive clutch.
            Misfeeds (jam code 010A) the first side of duplex. Overlay and single sided copies are not affected. Replace the paper pickup motor.
            If I remember correctly the 01xx part is the type of jam, and the xx0A is the specific sensor. =^..^=
            • mdm7266
              • Dec 2007
              • 99
              at power on still jam indication pointing at middle right door. cannot even make a single copy because at power on indicate jam.
              • teckat
                • 16083
                Time too get down & dirty,
                No miracle fixes.
                  • 23007
                  Do you know how to read the output directly off of each photointerrupter? =^..^=
                  • copier tech
                    • 8144
                    Have you checked the connector at the back on the fuser draw & in the back of the machine, small pieces of paper can get trapped causing phantom jam messages.
                    But if I was you I'd make your local scrap metal dealer happy!
                    You can purchase cheap reliable used copiers now from any local copier dealer.
