Canon IR2200 taking too long to warm Up?
  • doug
    • Dec 2011
    • 198
    Hi guys,
    I have a customer at a Church that claims it takes too long to warm up from power switch being turned om....this copier is in a Church that has no heat until Saturdays before services.
    The specifications say 29 seconds from power on, this machines is taking 2:35 according to my iphone stopwatch....any suggestions or should I just tell the customer its too cold in here!
    Haha
    Thanks,
    Doug
  • teckat
    • 16083
    Re: Canon IR2200 taking too long to warm Up?
    Originally posted by doug
    Hi guys,
    Haha
    Thanks,
    Doug
    like having printer outside on curb
    * When main power is turned ON: 29 seconds max.
    Temperature Control
    Normal
    [1] Power-on sequencepower-on/control panel input/document detection.
    Clean _& Re-seat the Memory Dimms and Boot ROM as an added measure
    • Corder
      • Nov 2014
      • 105
      Hi guys,
      Haha
      Thanks,
      Doug
      You can try to clean the heating element, but don't forget to apply fuser film grease.
      • teckat
        • 16083
        no room Heat in December > in New Jersey USA for an entire week until Saturday >
        Grease will not help that > unless u heat it on a stove
        • Corder
          • Nov 2014
          • 105
          No, but cleaning probably will
          • copier tech
            • 8131
            Does it hang at the boot up screen? More likely to be a HDD issue, if the machine was taking that long to warm up it would throw an E000 code etc
            • teckat
              • 16083
              Good Pointon HDD-
              • copier tech
                • 8131
                Exactly! 2 mins 34 seconds he'd deffo get a an error!
                  • 22999
                  You can also get longer warm up times and fuser errors if the press roller bearings are coming apart, but never 2:34. =^..^=
                  • teckat
                    • 16083
                    Would like to ask poster what the control panel shows,
                    ?? Slow Progress bar, Warming up, Wait or other.
                    Note: reminder_
                    Scanning originals while the machine is warming up, will cause warm up to take longer.)
                    There was a series that had a extended wwarm up issue with finisher attached & no error.
                    Remove finisher _printer came to ready_??
                    • JPiek
                      • Oct 2014
                      • 435
                      Have you timed the warming up when the church is heated ? i.e. shutdow the printer for a hour and powering it up again. If the church is heated, it shouldn't take the same time as in an cold church if that is the issue....
                      Johan
                      • copier tech
                        • 8131
                        To be honest room temperature won't affect the machine warm up time by much, a few seconds at most.
                        On newer colour machines they have a humidity sensor, the machine will detect a temperature change & will rotate the drums & ITB longer to clear any condensation, however this old 2200 series doesn't have that sensor.
                        • Corder
                          • Nov 2014
                          • 105
                          Nevertheless I'd try to replace the heater unit.
                          • copier tech
                            • 8131
                            These heater units either work or they don't. Also they are no longer available from Canon!
                            • teckat
                              • 16083
                              New Jersey
                              Wednesday 2:00 PM EST
                              Overcast
                              11
