E0000 001 ir 4570
  • AIT MAMEUR
    • Jun 2008
    • 59
    [Error Code] E0000 001 ir 4570
    Hi, i have the error code e 0000 001 in my IR 4570, i have changed the fuser and the DC control but the problem persiste. Son please anyone To help me.
  • copier tech
    • 8172
    Re: E0000 001 ir 4570
    Have you reset the error in service mode?
    • AIT MAMEUR
      • Jun 2008
      • 59
      Yves i do et in service mode
        Product : imageRUNNER 4570 series
        Title : E000 Error :000
        There were several symptoms:
        1st symptom was an intermittent error code of E000, sometimes the machine would
        run as many as 20k before the problem would re-occur.
        2nd symptom was the fixing film could be caked with toner.
        3rd and most common symptom was that the latch would catch when opening the
        Main Right Side Door, this can be remedied by adjusting the cover that can interfere
        with the fuser release (1 screw ) (this cover is added when installing the internal
        finisher). The common mistake in the field is to bend this latch instead of adjusting
        the cover.
        Workaround :
        Problem was that the latch that releases and applies pressure to the fixing film had
        been bent causing this mechanism to work erratically (proper and improper pressure
        when the Main Right side door was closed ).
        Solution was to replace the latch which is formally called the Hook Holder Unit; Part # FM2-0355-000
        • AIT MAMEUR
          • Jun 2008
          • 59
          Hello. i have replaced the right side door but the problem persiste.
          • copier tech
            • 8172
            When you say you replaced the fuser, did you replace the complete fuser unit or just the fuser film ass'y?
            • Canuck
              Tech Specialist
              • 1713
              This error means fuser is not heating up. Check the AC Driver..could be fried. Also if your right door switch is bad or not actuating properly, you won't get 24 volts at Dcon ....
              • AIT MAMEUR
                • Jun 2008
                • 59
                The parts which i replaced even the fuser unit and the right door or the ac card are working correctly.
                • AIT MAMEUR
                  • Jun 2008
                  • 59
                  Re: E0000 001 ir 4570 resolved
                  hello, i have resolved the problem. it was the new fuser changed which is bas quality. thanks for all.
