Hi, i have the error code e 0000 001 in my IR 4570, i have changed the fuser and the DC control but the problem persiste. Son please anyone To help me.
E0000 001 ir 4570
Tags: None
Re: E0000 001 ir 4570
Have you reset the error in service mode?Let us eat, drink, and be merry, because tomorrow we may die!
Product : imageRUNNER 4570 series
Title : E000 Error :000
There were several symptoms:
1st symptom was an intermittent error code of E000, sometimes the machine would
run as many as 20k before the problem would re-occur.
2nd symptom was the fixing film could be caked with toner.
3rd and most common symptom was that the latch would catch when opening the
Main Right Side Door, this can be remedied by adjusting the cover that can interfere
with the fuser release (1 screw ) (this cover is added when installing the internal
finisher). The common mistake in the field is to bend this latch instead of adjusting
the cover.
Workaround :
Problem was that the latch that releases and applies pressure to the fixing film had
been bent causing this mechanism to work erratically (proper and improper pressure
when the Main Right side door was closed ).
Solution was to replace the latch which is formally called the Hook Holder Unit; Part # FM2-0355-000
When you say you replaced the fuser, did you replace the complete fuser unit or just the fuser film ass'y?Let us eat, drink, and be merry, because tomorrow we may die!
The parts which i replaced even the fuser unit and the right door or the ac card are working correctly.Comment
Re: E0000 001 ir 4570 resolved
hello, i have resolved the problem. it was the new fuser changed which is bas quality. thanks for all.Comment
