error e0000070-0001
  • 4raddoo
    • Oct 2011
    • 30
    [Error Code] error e0000070-0001
    please can someone help me how to remove itb from canon ir3100cn and clean inside. if possible video tutorial.
    thank you
    waiting for your reply
  • canon33
    • Jun 2014
    • 65
    Re: error e0000070-0001
    Been quite awhile since I did this but it comes out rt side. Remove rt door and fuser. In front remove drum and inner finisher. I think then u can remove itb cleaning assy from top. On rt side there are 2 screws holding in itb. This should get u started. If u are successful then remove belt from assy and clean inside belt especially white patch on inside edge of belt. Make sure u put the belt back on the same way so it reads the white patch for home posit ion of belt. Good luck!!
    • teckat
      • 16083
      thank you
      in here somewhere
      • copier tech
        • 8202
        You've just reminded me what an aufull m/c this was, nearly an hour to get the transfer belt out especially with the internal finisher.
        Only got one of this series left on contract, they mainly use it for b/w so its surprisingly reliable!
        • vigour
          • Aug 2010
          • 1038
          Originally posted by teckat
          in here somewhere
          You posted a youtube video long ago
