The corona up top has a cleaning blade, this one is real bad, how important is it ,if so i cant find part # anywhere and precision roller cant seem to show it... thanks for any information..
ir 9070 main corona up top
Re: ir 9070 main corona up top
The corona doesn't have a cleaning blade, a cleaning pad? If the corona unit is old I would replace the complete unitLet us eat, drink, and be merry, because tomorrow we may die!
Thats not the main corona then! That is the pre transfer, replace the complete unit not expensiveLet us eat, drink, and be merry, because tomorrow we may die!
The main charging corona is on top of the drum,on the right lower side of the rail that holds it up, is a cleaning blade that makes contact with the drum..this is what i am talking about..on the lower side of the drum is the per transfer corona ,to the left of it is the main transfer corona,the corona i am talking about, sits at 12 o'clock..thanks for your response.Comment
the corona at the top is the primary corona and yes there is a wiper blade that if i remember is on the rial for the potential sensor it would be part of the drum carrier assembly could not find a part number what is the problem you are seeing i know on some old machines where they have deteriated(sp) i have just removed the stripComment
Just having several spots on copy wanted to replace so i could eliminate the thought of it being problem.. having to replace drum again..just wanted to put back on so i didn't have to suspect it in the future as a problem..thanks for your thoughts.Comment
You're replacing the drum "again" ???Let us eat, drink, and be merry, because tomorrow we may die!
You might want to change those coronas if you didn't already or you may pepper another drum.Comment
If all the 3 corona units are nearly new you wont need to replace them again with the 2nd drum.
Give the the process unit & dev unit a good vacuum while your there.Let us eat, drink, and be merry, because tomorrow we may die!
