ir 9070 main corona up top
  • rdc
    • 53
    The corona up top has a cleaning blade, this one is real bad, how important is it ,if so i cant find part # anywhere and precision roller cant seem to show it... thanks for any information..
    • 8164
    Re: ir 9070 main corona up top
    The corona doesn't have a cleaning blade, a cleaning pad? If the corona unit is old I would replace the complete unit
    • rdc
      • 53
      The rail on the right side of the main corona has a blade on the bottom edge there is a piece broken out of the center...
        • 8164
        Thats not the main corona then! That is the pre transfer, replace the complete unit not expensive
        • rdc
          • 53
          The main charging corona is on top of the drum,on the right lower side of the rail that holds it up, is a cleaning blade that makes contact with the drum..this is what i am talking about..on the lower side of the drum is the per transfer corona ,to the left of it is the main transfer corona,the corona i am talking about, sits at 12 o'clock..thanks for your response.
          • Northwestservice
            • Jan 2011
            • 140
            the corona at the top is the primary corona and yes there is a wiper blade that if i remember is on the rial for the potential sensor it would be part of the drum carrier assembly could not find a part number what is the problem you are seeing i know on some old machines where they have deteriated(sp) i have just removed the strip
            • rdc
              • 53
              Just having several spots on copy wanted to replace so i could eliminate the thought of it being problem.. having to replace drum again..just wanted to put back on so i didn't have to suspect it in the future as a problem..thanks for your thoughts.
                • 8164
                You're replacing the drum "again" ???
                • rdc
                  • 53
                  Yes,, bought a used one after 45 days silicon pitted in a few spots . one one very noticeable and several micro spots. bad luck i guess.
                  • 20 year tech
                    • May 2014
                    • 577
                    You might want to change those coronas if you didn't already or you may pepper another drum.
                    • rdc
                      • 53
                      Just put in new transfer corona..put in main and transfer when I replaced drum you think I should do again?
                      • rdc
                        • 53
                        replaced trans fer corona 2 weeks ago..replaced main charging and transfer corona when i put drum in it,you think i should put them in new again,,thanks for your thoughts..
                          • 8164
                          If all the 3 corona units are nearly new you wont need to replace them again with the 2nd drum.
                          Give the the process unit & dev unit a good vacuum while your there.
                          • rdc
                            • 53
                            Vaccum once a week also clean and scrape the wire contact area of the corona once a week..thanks for feedback.
