Canon IR Advance C5035
  • Reed
    • Feb 2011
    • 258
    This machine will not fax out or receive. I get no dial tone. I have tested the phone line at the wall and it tested good. Changed out the phone line. Replaced the entire fax PCB assembly. I even rolled the machine to a different room and connected it to a known working phone line. Still no dial tone and not faxing. Has anyone seen this before.. any ideas... Thanks in Advance
  • copier tech
    • 8132
    Re: Canon IR Advance C5035
    I'd start by updating the firmware.
    Then initialize the fax in servce mode, then set it to your correct country/line type
    • MrB
      • Nov 2009
      • 147
      No something stupid as the volume turned down by any chance..??
      If you press "On Hook" on the display, do you here the relay clicking at all..?
      Just a wild stab in the dark, for something so silly
