iR-C4080 color registration
  • aAandy
    • Apr 2012
    • 370
    hello everyone
    have a client with a machine, color registration was misaligning once a month - i'd reset laser units & perform quick gradation to correct
    after 3 occurrences, i decided to remove & dismantle the IBT & clean it all up, cleaned the belt inside, cleaned all the rollers etc, cleaned the sensors assembly & i also installed a new IBT cleaning assy - when i put the IBT back in the machine & reset the laser units, the color registration was WAY OUT
    4mm between black & cyan, then 3mm to magenta, then 3mm to yellow
    tried resetting lasers (service mode 2,,, function,,, laser) all OK
    tried 10 quick gradations,,, no change
    tried full gradation, printed 1 chart, but would not read/scan it - kept telling me to place it correctly - the yellow registration was so far out, there was no lead edge blank on the yellow part of the gradation chart
    printed out a network report & its registration was way out (trailing edge black border was right on the trailing edge of the page)
    any pointers would be very much appreciated
    thanks in advance
    Andy
  • canon33
    • Jun 2014
    • 65
    Re: iR-C4080 color registration
    Try clearing registration under function-clear-reg
    • pontiac
      • 420
      Most of the copiers that we buy used have a color registration issue, either lasers lose there settings or transfer belt is stretched and causes serious registration issues. Depending on how old the belt is when you took it apart to clean and made things worst tells me your belt is no good also ck the rubber transfer drive rollers for cracks. Good Luck
      • copier tech
        • 8132
        I agree, they ITB belts can streech over time & slip.
        Order a new belt, clean the itb rubber rollers VERY WELL.
        Then do a DC con clear. If no joy do a p print then do a MN Cont clear
        • teckat
          • 16083
          Originally posted by aAandy
          hello everyone
          thanks in advance
          Andy
          once the gradation calibration patches are off alignment > u will not be able to do your Auto Full Glass Gradations > issue needs to be repaired first
          There many issues that cause reg issues on this model
          ITB, ITB BELT,
          ITB DRIVE Swing GEARS, // the Helical Gears (////)wear & walk over each one
          LASERS
          Drum Drive Issue Assembly (FM2-5360-000).
          Color Miss-registration in Sub Scan Direction Only.
          Service mode (Level2) > COPIER > FUNCTION > CLEAR > REG-CLR
          (If this Service mode is enabled, auto-registration detection correction values are
          cleared.)
          is your registration problem >
          a CROSSFEED ISSUE-----Main Scan
          a PAPER FEED ISSUE----Sub Scan
          or both directions
          • aAandy
            • Apr 2012
            • 370
            thanks everyone for your replies
            the IBT assy was replaced a few years ago, but has done less than 50k (machine about 250k old) - all the IBT rubber rollers are in very good condition - all gears are in good condition - everything cleaned to perfection - absolutely no belt slip
            registration trouble is in paper travel direction only - sub scan
            i can't imagine it's the lasers, as when i arrived i did the normal laser reset & quick calibration which corrected the minor color registration issue (0.1mm) - only after i did the IBT did things go awry & i checked by holding the belt still & turning the drive gear by hand, i could not get the belt to slip at all
            i'll reset Service mode (Level2) > COPIER > FUNCTION > CLEAR > REG-CLR & re-check the IBT assembly & seating & see how i go
            if anything else comes to mind,, feel free to reply
            thanks again !
            • aAandy
              • Apr 2012
              • 370
              update
              we'll i'll be
              performed the resets & gradations, no change
              removed & dismantled the IBT assy again & it looks like i didn't have the belt centered correctly, so the rubber strip on one side was riding the drive roller white spacer
              fitted belt correctly & remounted IBT, reset everything, performed 3 quick gradation calibrations, 1 full calibration & fiery calibration
              problem solved, machine working like a charm
              thank you everyone for your assistance, it really is very much appreciated
              special thanks to teckat who has been of massive benefit with all my lil 4080 problems - your input has been most beneficial every time
              Regards
              Andy
              • teckat
                • 16083
                update
                we'll i'll be
                Regards
                Andy
                ________________
                Welcome :-D
                Note:
                U can't turn the ITB by hand fast enough to simulate printer speed & check slippage or drift of belt.
                Lesson learned moons ago_>
