cannon np 7130
  • binsfields
    cannon np 7130
    Hi there how do you adjust the auto exposer. when on to dark
  • deep
    • Jun 2008
    • 208
    It is better to clean the optical section first, then tune the darkness by turning the Density Correction Dial clockwise or counterclockwise.
    Kenny
      • 23010
      The handbook has three pages on this subject. I won't pretend that I remember it all. I recorded this tip:
      Light copies using AE. Automatic Exposure is adjusted within handbook specs. Confirm that Canon OEM toner is installed. 1) Adjust lamp intensity. 2) Re-adjust AE to these specs: 1) Center the exposure dial VR107. Enter '38' in service mode, and press the Start key. The existing setting will flash. Enter new value using +/- keys. Press AE to store the new setting (between 0-99, higher setting = darker copies, lower setting = lighter copies).
      I hope this helps. =^..^=
