Quick question as per title, are these two firmware versions the same? both machines look very similar.
IRAC2030 & IRAC2230 firmware the same?????
Tags: None -
Re: IRAC2030 & IRAC2230 firmware the same?????
Another question of you don't mind!?
Are there two types of firmware, eg: one you use the SST to create a USB boot pen drive & another version that you simply copy onto a USB pen without using the SST?Let us eat, drink, and be merry, because tomorrow we may die!
Thanks TKLet us eat, drink, and be merry, because tomorrow we may die!
So ive just downloaded this file from Canon UK called " 20150126iAC2030v440101USJP20141211.0440101" when unzipped it has dozens of files, do I basically unzip this file directly to the USB pen drive????
Is this the USB firmware files.jpgLet us eat, drink, and be merry, because tomorrow we may die!
When you unzip the ones from Canon USA it should give you only 2 main things a folder (with many items in it) and a .ift file. Load both of directly onto the root of your USB drive. Insert USB into the machine and power it up while holding 2 & 8 and you should get a menu. I usually choose over write all. Hope this helps.Comment
Maybe the UK site is different, I can register the files using the SST then create the USB fine, but not sure what files to download to put on the USB without using the SST!Let us eat, drink, and be merry, because tomorrow we may die!
Does the UK site offer you the ability to download either an SST version or a USB version?Comment
don't expand the unzipped file/
have u installed the SST PROGRAM_???
when u install the SST PROGRAM > it creates Canon default location folders (example below)C:\Canon File Folder\SST System Software Folder_in here u will see SST Files folder & USB Files folder.
u extract the iAC2030 ZIP FILE to this location _C:\Canon File Folder\SST System Software Folder\USB Files
under USB Files u will see
and drag the entire iAC2030 folder( don't expand/open folder) into USB STICK
FILE LOCATION.jpgLast edited by teckat; 04-23-2015, 06:40 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**
ADVANCE PRINTERS have the ability to use >>
a Content Delivery System (CDS) for : see attach
/ Authorized Dealerships, also have access to LCDSThe benefits of CDS include:
Attached Files**Knowledge is time consuming, exhausting and costly for a trained Tech.**
what type of Firmware ver did u download ?
SST or USB ?? u actually don't need to register in SST (see my easy way//)
when u download and follow location install prompts> they will be loaded into the Canon Folder locations/
u can drag either the SST ver for model or USB ver for model into a stick
USB is a scalded down ver that eliminates some languages/rui depending on country where firmware is downloaded.
here is a pic on / SST to USB Action
SST_USB.jpg SST_USB STICK.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.**
Canon uk does not have usb ready files, you need to register the firmware in sst then put the firmware on the usb stick using sst.
The firmware you need is this,
Capture.jpgComment
