CANON IR2420
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] CANON IR2420
    Hello so l have canon ir2420 to repaired there ..firstly this machine have this message : updating fw
    Latest version : 12/04/2010
    8N
    So in my opinion l should be updating her fw ..to contacted my laptop with this machine by usb ...please how version of sst l use this operation ..cause l have lot of version but l need have more information about this operation .
    BEST TECHNICIAN . NICE PEOPLE .
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: CANON IR2420
    Go to service mode and select download.
    System software programs to be downloaded need to be registered in the SST.
    Use the latest sst of your many versions.
    Don't power off when data writing!
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      Re: CANON IR2420
      thank you ..but if l try enter service mode ...but unfortunate l can't enter please help other how version sst you use it .. v321e ; v334ej...; v463eg....
      • zoraldinho
        • Mar 2008
        • 5015
        Re: CANON IR2420
        Use highest version but they must work with all version.
        Service mode on this model is standard but 28 is not at the same time if I remember...
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          Re: CANON IR2420
          my latest sst version l have is 463eg ...l trying enter service mode by * 2 8 * ok .....but l can't ...it have any idea ?
          • zoraldinho
            • Mar 2008
            • 5015
            Re: CANON IR2420
            Did you try not the same time 2 and 8?
            Press the Additionalfunctions
            key, 2key, 8key, Additional functions
            key sequentially.
            • zaza
              MECANOGRAPHE
              • Mar 2008
              • 1095
              Re: CANON IR2420
              [QUOTE=zoraldinho;472055]Did you try not the same time 2 and 8?
              key sequentially.[/
              Surly l doing all this operation but never enter ..very strange l do this operation lot of time in my history ...
              • laitang
                • Nov 2012
                • 627
                Re: CANON IR2420
                Using the Service Mode in canon IR2420:
                [Method of entering the service mode]:
                Press the Additional Functions key and # key, then enter the service mode.
                [Method of operation the service mode]:
                Select the service menu using the upper/lower/left/right keys and OK key.
                • zaza
                  MECANOGRAPHE
                  • Mar 2008
                  • 1095
                  Re: CANON IR2420
                  well ...l have question ...if l check the mother board of this ir2420 and making there in other ir 2420 l can do it this operation ..cause the problems only consisted this mother board section ?
                  • copier tech
                    • 8171
                    Re: CANON IR2420
                    Turn the machine on while holding down 2+8 keys will take you into save download mode, then you can install the firmware
                    • zaza
                      MECANOGRAPHE
                      • Mar 2008
                      • 1095
                      Re: CANON IR2420
                      well my friend Copier Tech if l making the mother board of this bad machine and l making in another same model ..l can slove this machine ?
                      • copier tech
                        • 8171
                        Re: CANON IR2420
                        Yes I guess you could swap the dc controller board if you have a spare
