upper and lower roller
  • daddyravi
    • Sep 2025
    [Misc] upper and lower roller
    i need help. how to adjust the pressure of lower and upper roller in fixing unit for IR5000. i mean, are there any ways to set the pressure exactly.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: upper and lower roller
    Make the following selections in service
    mode to discharge the paper:
    COPIER>FUNCTION>FIXING>NIPCHK.
    Cereme still standing?
    Good luck!
    • daddyravi
      do i have to place a paper first beetween those roller? i've try it copier-function-fixing-nib chck. but it say NG.
      • zoraldinho
        • Mar 2008
        • 5018
        No.Wait for 15 min after the machine completes warm-up, and make 20 A4 copies before starting to measure the nip.Be sure that both upper and
        lower rollers are sufficiently heated when taking measurements.
          • 23010
          You're wondering how you get the nipp pattern.
          Load A3 or Ledger paper.
          Raise the ADF.
          Make a black copy, then pop open one of the doors when the paper is in the fuser unit. (It may take you a few tries to figure out the timing.)
          Wait ~15 seconds.
          Quickly roll out the jammed paper.
          Examine the glossy area where the fuser rollers rested.
          Measure the nipp at both ends and center.
          Adjust pressure springs.
          Repeat.
          If you've got a damaged or worn roller, install a new one before doing the adjustment. =^..^=
          • copier tech
            • 8222
            To do the NIP check you need to load paper in the bypass, it wont work from the cassettes.
            You shoukdn't ever need to ajust the NIP pressure, if you're getting poor fusing etc id look at the upper bushings & bearings, especially the pressure roller bearings.
