canon ir2022: frozen: connection to pc is completed message
  • mntech
    • Aug 2010
    • 250
    [Dead] canon ir2022: frozen: connection to pc is completed message
    Machine boots and just says connection to pc is completed and shows an ip address of 192.168.0.215 (which is not the address that was assigned to it)
    No functions or buttons work, cannot access service mode.
    When booted without network cable plugged in, just shows a message: waiting...
    Tried connecting machine with a network crossover cable to my laptop with a static ip 192.168.0.200 and can ping 192.168.0.215, but cannot access web interface. Didn't have print driver, but tried with a similar Canon driver and generic hp LaserJet4 driver and prints failed.
    Tired booting with dongle from net board removed, same results, swapped ram, let machine sit at waiting...., never codes out our displays anything else.
    Not sure what to try next, was thinking of pulling battery on net controller to reset network config.
    Any thoughts?
    Thanks,
    Mntech
  • mntech
    • Aug 2010
    • 250
    Re: canon ir2022: frozen: connection to pc is completed message
    I forgot to mention, the machine was functioning perfect and printing yesterday.
    Also computer recognizes machine when usb plugged in and shows same connection is completed message, but without the ip address. Still was unable to print
    • copier tech
      • 8144
      I'd start by updating the firmware, it it is up to date rewrite it. Im guessing you can boot into safe mode in order to update the fw?
      • mntech
        • Aug 2010
        • 250
        I do not have the firmware for this machine, if anybody can supply it to me our let me know where to find It, I would appreciate it. Also how do you boot the machine in safe mode, and what type of card is required for firmware?
        • copier tech
          • 8144
          You can use any USB pen drives under 4GB
          Heres a link to the firmware & service manual, you'll need to copy & paste the link into your browser.
          mail.davin.be:8888/CANON/COULEUR/CANON%20IRADV%20C22xx/IRADVC2220
          • mntech
            • Aug 2010
            • 250
            Thanks for the reply, but it appears the link you gave me was for an imagerunner advance c2230, i need the firmware for the IR2022
            • copier tech
              • 8144
              Sorry! here's the irac 2022!
              mail.davin.be:8888/CANON/COULEUR/CANON%20IRADV%20C20xxi/
              • mntech
                • Aug 2010
                • 250
                Thanks,
                I still don't think thats right LOL
                i need the B&W model Canon imageRunner 2022
                not advance color
                I looked around on that site and didn't see it, closest i saw was the ir1022 but not the ir2022
                • copier tech
                  • 8144
                  Hi,
                  I see, sorry I don't have the ir2022, but is it the same as this series?
                  Index of /CANON/NB/CANON IR 2420
                  • Trodelphin
                    hey mntech did you end up sorting the problem out ?
                    I've got the same machine with same issue :/
                    • Trodelphin
                      How did you go with the Firmware for the iR2022 ?
                      chasing it myself for a machine that keeps dropping the firmware :/
                      Cheers
