Copyboard fell off
  • evest
    • Aug 2008
    • 58
    [Misc] Copyboard fell off
    Fixing on an imagerunner 2200 and the copy board fell off. I see alot of foam pads with bad adhesive that most like held it on. Do some of you know a way around ordering the pads. machine not worth the cost of the pads most likely.
    Thanks.
  • teckat
    • 16076
    Re: Copyboard fell off
    Thanks.
    Velcro / or
    Double Sided Foam Adhesive Tape
      • 22994
      Me too. I prefer the sticky Velcro. It's easier to position or re-position the matt. 1" square pads or 1" roll cut into 1" lengths works quite nicely. Take the time to remove the old adhesive or it won't adhere very well. =^..^=
      • Canuck
        Tech Specialist
        • 1715
        Weatherstripping....use it all the time. Clean the old glue from the old copyboard. I use 3/4 inch wide about 3/16 thick(get it from Home Depot). Cut into squares, then heat a glue stick with a lighter,dab some glue on copyboard, then place foam square FOAM SIDE down onto glue. Peel off white paper on each, line up the copyboard, and install into place. Works like a charm
        • teckat
          • 16076
          good point/ suggestion
          always ask if can use a open flame in customers office
