IRAC 5030 Black blobs of toner
  • copier tech
    • 8132
    [CQ] IRAC 5030 Black blobs of toner
    I've got an irac5030 it's putting small black spots of toner, looks like a unit is leaking however no units are above the paper feed, quite intermintent, every 20 prints or so, always in the same place.
    I have fitted a new transfer cleaning unit as it was at 107% life, this made no difference.
    All the other drums & dev's are all under 70%
    I have a black dev unit on order now, not sure what else it could be!?
  • teckat
    • 16083
    Re: IRAC 5030 Black blobs of toner
    Is there black developer in waste bottle_?
    If so, your on right track, ___
    HVT 2 provides the primary charge for the black drum, could be an added issue.
    • copier tech
      • 8132
      Thanks, the print quality is perfect, all excellent solids etc.
      I see what happens after I replace the black dev!
      • copier tech
        • 8132
        I went back to this one & fitted a new black dev unit, but it is still producing small black blobs of toner on the prints!
        I'm going back with a black drum, but has anyone else got any suggestions?
        Thanks.
        • teckat
          • 16083
          Thanks.
          If u run off 30 Blank copies, do u still get spots on paper_?
          • Paul 75
            • Oct 2008
            • 97
            What life is your fixing film assy ? I replace mine about 300k but check for build up on the blade before this.. Are you using genuine toner also ? I would do both dev and drum if not..
            Oh...... I can't copy at the moment then ? !!!!!!
            • copier tech
              • 8132
              Changed the drum today, still no good, although it is better, only an occasional tiny blob of toner every 20-30 pages of so.
              Fuser life is still OK. But yes maybe there is toner build up on the fuser guide etc!
              Always used genuine toner first thing I thought of.
              • canonbundy
                • Jun 2012
                • 607
                Maybe clean 2nd t/fer roller & its housing.
