IR 3035
  • Kurt
    • 56
    [Jamming] IR 3035
    I have a jam code of 0107 followed by 09 in next column. Usually that tells me where it was fed from can't find 09 in book. Thanks, Kurt
  • charm5496
    • 2387
    Re: IR 3035
    If memory serves me right that tells you the paper feed position and 09 is the duplex unit
    • Canon345
      Re: IR 3035
      Could be due to high humidity, a curl in the paper. Also the black flapper on the door has two black pads under it. Those need replaced with the undated white pads. This can stop some of those wierd duplex jams. I think 0108 was another sign for the pads. There are settings in the book to prevent the curl like changing fix temp to 3 .
      • hinbox
        • Jul 2014
        • 22
        Re: IR 3035
        yes he is right about the pads you can use velcro felt if you dont have pads available
        • Harry
          • 228
          Re: IR 3035
          Or remove them at all
          Harry
          • Canon345
            Re: IR 3035
            Harry
            I would not remove the flapper pads. The reason for the Canon redesign of the black pads was to get rid of the flapper sinking into the pad over time. When its old and flapper has sunk into the pad, the jamming starts. Plus removing the pads doesn't stop jamming! So please upgrade all your machines to the white pads at least on the outside under the flapper.
            • dan7777
              • Dec 2012
              • 680
              Re: IR 3035
              We have hundreds of machines with the pads removed. My company does not stock the new pads, just says to remove them. They all seem to work ok. Can't remember code that the pads cause but 0208 comes to mind.
              • pinheiro
                • May 2009
                • 51
                Re: IR 3035
                That jam it pick up only when you double site print...so trust that, without the pad's in high humidity environment you will pick up that jam...trust!
                • Canon345
                  Re: IR 3035
                  Its a real mystery because I have stopped the 0208 jam by removing the old sunken in pads and replace them with a new black pad or updated white pad. Have seen peeps remove the pads and still cant get rid of the jams.
                  I wonder if a worn duplex clutch or belt is also to blame?
                  • copier tech
                    • 8193
                    Re: IR 3035
                    This series of machine always jams in the fuser during humid weather.
                    If the customer does a lot of double siding advice them to use 100gsm paper, slightly thicker it has less tendency to curl & jam on the 2nd side.
                    • pinheiro
                      • May 2009
                      • 51
                      Re: IR 3035
                      Hi
                      0208 jam it is stationary jam, could be on duplex section ( by the door, some paper, clutch fault, or sensor fault behind the flapper, you have to check) or the 1st delivery roller ( the bearing could be moved out from the position) and normal it pickup jam 0108, but if it get stack could be 0208 Jam.
                      Good luck
