Epson T5270 servprog.exe
  • Docu flowovm
    • Jul 2024
    • 1
    #46
    trying to reset admin password as the admin password has been lost over time admin password has been changed from default and need to acces the machine to change the IP address due network reconfig
    • GIUBOSS
      GIUBOSS commented
      Editing a comment
      If you forgot the administrator password you created during network setup, select Restore Settings in the Network Setup menu to set a new password
  • kuby
    • Oct 2007
    • 1408
    #47
    How do you setup a Epson WF-C4810 to email using a Office 365 account? The printer appears to be wireless. Did not set this up but once logged into their computer I can see the printer and the setting and verify the Auth methods
    Auth method - SMTP AUTH
    Auth account - **********
    Auth password - *********
    SMTP server address - smtp.office365.com
    SMTP server port number - 587
    Secure connection - STARTTLS
    Errors out when tested
    are these setting correct?
    • guitar9199
      • Sep 2016
      • 1100
      #48
      Hey Troops,
      I have an Epson AM-C4000 with 4 cassettes and an inner finisher. When it was installed, everything worked fine, then a couple of months back they started getting a "Wrong paper size" error.
      I followed through the video clips on removing the belt unit and was able to check and clean the paper sensor. I reassembled everything, and trays 2-4 plus the bypass tray all worked properly, but cassette 1 still throws a paper size error.
      I'm stuck.... does anyone have any ideas?
      Thanks in advance,
      Steve
      • guitar9199
        guitar9199 commented
        Editing a comment
        Hey gang...
        Quick update, I went and re-cleaned the paper sensor behind the belt, and I also updated the firmware. Everything works as it should now.
        Thanks for the assist!
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 703
      #49
      Originally posted by guitar9199
      Hey Troops,
      Thanks in advance,
      Steve
      I would make sure that the tray hasn't moved. A recent firmware update has changed the way you check and adjust centering. We had one in the field that was having issues like you're experiencing, and after the tech adjusted all of the trays, they don't have that issue anymore. He didn't notice any issues with the output at first, but couldn't argue with the results.
      • AlbertK
        • Jul 2014
        • 90
        #50
        Good day all,
        Any ideas on how to get rid of all the virtual USB ports listed in the Epson adjustment software? Have so many ports (more than 100) causes command issues.
        I have tried sending commands to registry using script (.bat) but for some reason the ports remain in the Epson software.
        I have also tried to uninstall reinstall the software with no positive results.
        Someone told me to do a Windows reset and setup all programs (Office 365, Outlook...) but this a bit drastic.
        Any help would be appreciated.
        The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
        • Hart
          Hart commented
          Editing a comment
          Maybe with Device Cleanup Tool ?
          reset USB port, restart USB port, close window by commandline, increasing COM port numbers, DeviceCleanup, Device Cleanup, remove hidden devices from device manager, ioctl decoder, DeviceIoControl Decoder
          Run as administrator
        • AlbertK
          AlbertK commented
          Editing a comment
          Thank you for the reply.!
          I managed with a script (.bat) file created in AI. Deleted all the drivers, reinstalled the ones I needed.
          Worked like a charm.
      • Kazzy
        • May 2023
        • 64
        #51
        After Upgrading MY SC T5200 with the PS3 Unit the Epson Print Automate doesn't work at all citing the correct driver isn't installed. I uninstalled the regula driver and installed the PS3 driver from Epsons website. Even the layout manager doesn't work properly with that driver. Are all the Layout and Print Automate programme just for the regular models and not the PS models?
        • EzSkeez
          • Jun 2023
          • 10
          #52
          Hello Techs,
          Does anyone have any information on the manual feed tray rollers of this model. I have a service manual, but there is no section on how to get to the manual feed tray feed rollers.
          Any help would be much appreciated.
          • EzSkeez
            EzSkeez commented
            Editing a comment
            I am talking about the bypass. Thank you Hart. Appreciate it.
          • EzSkeez
            EzSkeez commented
            Editing a comment
            Hi again, you wouldn't know how to retrieve the input ID number for service support mode for this model?
          • EzSkeez
            EzSkeez commented
            Editing a comment
            Fyi - wf-c789r service mode:98308
        • newdente.gianluca
          • Feb 2016
          • 60
          #53
          Good morning, I have this printer with error code 032051, the manual says that it could be the contact of the additional drawer (I don't have the additional drawer) I also tried to disconnect the contact located under the printer from the mainboard, has anyone solved this problem? thanks .
        • boutn
          • Jun 2016
          • 547
          #54
          Any of you know why this plotter is saying its 'offline' on the webpage?
          I can reach the webpage, but the customer can not print.
          • ihatefinishers13
            ihatefinishers13 commented
            Editing a comment
            Maybe subnet or Gateway is wrong? change it to DHCP and see what happens and what info it pulls? Snap a picture of how it's set now though, including DNS.
            Also had one of their plotters a few weeks ago not be able to scan to folder, had to wipe it back to factory and put the settings back in because I tried everything else. Had similar issues with the WF series MFP's. Something about their initial config can get screwy, so you wipe it and it ends up fine.
          • Hart
            Hart commented
            Editing a comment
            Is the driver port with the hostname instead of the IP address ? Not related with the Offline message but I had problems when the driver was using the hostname instead of the IP, and for whatever reason it stopped working (and it was fine for the driver with IP).
        • Bob1932
          • Nov 2024
          • 5
          #55
          I am trying to diagnose an Epson WF-R5690 MFP. The printer displays "Contact Epson Support", no codes are shown. I was able to get into the maintenance mode and it displayed " Fatal Error code 8ah" I tried all the usual online searches and cannot find this code anywhere. Thank you for any input you might share.
