Bizhub 600 will not print? Question
  • Jag_97470
    • Aug 2015
    • 12
    Hello everyone, strange problem; This copier has never printed, customer only copied, copier only at 150K. Customer moved copier to another office that they now want to print. All network settings seem ok, so I hooked up laptop to test. From laptop as seen from PC I can ping ok, can access UI ok, but it will not print! no data light ever comes on. I did notice there are tabs missing, for example; no tab for configuration printout, no Printer tab! You can view all IP setting and network is turned on. Another tech I called seems to remember a small 4 pin print eprom on the main board? I don't know if this is true. Just wanted to run this by you guys and what do you think? Thanks guys!
  • iceman490
    • May 2014
    • 46
    Re: Bizhub 600 will not print? Question
    I cant recall the model number for the eprom chip but the 600 750/601 751 does require an eprom chip to print
    • Jag_97470
      • Aug 2015
      • 12
      Thank you sir; Do you know if this was an option or came standard on the board? Just wondering if it is standard maybe the chip is corrupt. It sounds like to me it must of been an option. Thank you again for the reply.
      • iceman490
        • May 2014
        • 46
        The print eprom was optional
          • 23006
          If you can still find it, it's called an IC202 PCL/PS image controller
          You can get this sort of information from the brochure, like this: http://www.clinesbe.com/brochures/bizhub%20600.pdf
          • Jag_97470
            • Aug 2015
            • 12
            Awesome! Thank you guys for your time.
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              When it was new that chip was around $2500. I sold one to a customer.
