DF-624 Driving me nuts. Paper Jam!
  • Mitch Barron
    • Mar 2013
    • 180
    [Jamming] DF-624 Driving me nuts. Paper Jam!
    greetings all!
    Hoping for a little direction here. Hope you are all doing well by the way! I currently have 5 different ADF with the same jam problem and I cannot find the problem. When scanning multiple documents the first 7 to 10 will scan through fine and the next will jam. Funny thing is, is that the page en route is in the same position on all the machines when the jam occurs. Leading edge is sticking out 3.5-4.5 cm into the output tray. I have cleaned and cleaned and changed sensors and rollers out with no success. Even 2 machines are standing next to each other and they are both doing it. Can anyone familiarize themselves with this problem? Next time i go I am going to leave the screwdriver in the shop and bring the sledge along instead. lol. Thanks heaps in advance if someone could shed some light on something to try?
    All the best! Have a nice weekend!
    Mitch Barron
  • kingarthur
    • 1376
    Re: DF-624 Driving me nuts. Paper Jam!
    telling us what the jam code is might help......
    • Synaux
      • Mar 2012
      • 1224
      You might want to also go into service mode and do a sensor check to manually ensure all the sensors are operating properly.
      What is the condition of the originals? Obviously, folded and punched paper can cause all sorts of issues....does it jam the same way with cardstock?
      • allan
        RTFM!!
        • 5462
        Test that with scanning in different resolutions. You could find that scanning higher that 300X300 dpi would eliminate the problem. I don't know how to fix that.
        Whatever
        • splblazer91
          • Jul 2014
          • 204
          Not doubting you Allan but how would resolution affect this? Transport speed maybe? educate me please
          • rrrohan
            • Sep 2011
            • 1977
            Have you performed the ADF calibrations with the test chart
            Sent from my SM-G900I using Tapatalk
            • Mitch Barron
              • Mar 2013
              • 180
              hey all,
              appologies for including the jam code (6605). I have been run off my feet lately and the customers are already calling this morning again. Originals are new pages, no creases, not folded, not moist, perfect. I have not tried changing resolutions, but am willing to try anything now. I have checked the sensors in service mode and all appears to be good. Was unable to find the writeup on the code 6605 in the service manual, but perhaps someone here has had some experience with that specific code? Will try the calibrations now and resolutions and let you know how I get along. Thanks for the suggestions.
              all the best!
              Mitch
              • Mitch Barron
                • Mar 2013
                • 180
                The ADF i brought in the shop here is just jamming and jamming. calibrations and resolutions resulting in jam. Thanks for the suggestions
                • Mitch Barron
                  • Mar 2013
                  • 180
                  Just an embarrassing addition. I now have found the code in the service manual. I don't know how I missed it. Anyway, i attached the write up. Hope someone has some insight. Thanks again
                  • kingarthur
                    • 1376
                    Clean the part that reflects back to PS4, I had this intermittently, there was paper dust on the reflector so the sensor thought that there was paper there
                    • Kidaver
                      Ghoulscout
                      • Apr 2011
                      • 912
                      Is it when you are running copies or when you are scanning documents. There has been known issues when people who do high volumes of scanning seem to get jams. Copy speed and Scan speed are different. There were several things to do for this. Adjust tension on reading motor, change front and rear levers, change flag sensor that wears out, add small washers to rear hinge of DF cover so it doesn't wiggle. Was quite a few TBs on it.
                      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
                      • allan
                        RTFM!!
                        • 5462
                        Hehe wrong kind of problem.
                        Cleaning out the square cavity with the matt finish helps.
                        Whatever
                        • 3boydad
                          • Aug 2015
                          • 27
                          when paper just stops and gives jam. 99% of the time you have a dirty sensor. check the sensors that sense paper enter and exit through adf. if clean you may need new one. and no they are not all the same. So if you changed out the sensor with what "looks" like the same one, there may be your problem right there. Every ADF that has paper just stop before the deck was dirty sensor. If paper is crooked look for mylar issue.
                          • Mitch Barron
                            • Mar 2013
                            • 180
                            Hey Everyone!
                            Sorry it took me so long to give the results of this issue. Issue was with the area opposite the solid state switch (PS4). Seems to be a picky little spot when it comes to dust and such (and quite a pain to clean properly too). All the best for the help and suggestions! Greatly appreciated!! I am a happy man!
                            Thanks again!
                            Mitch
                            • allan
                              RTFM!!
                              • 5462
                              Originally posted by Mitch Barron
                              Hey Everyone!
                              Thanks again!
                              Mitch
                              Use a blower brush.
                              Whatever
