DF-624 Driving me nuts. Paper Jam!
  • rrrohan
    • Sep 2011
    • 1977
    #31
    Re: DF-624 Driving me nuts. Paper Jam!
    Maybe the guy was just little drunk when posting. You know this evil spirit making saints sinners 😂😉
    ud have to be very bored to drunk browse a copier forum
    • copyman
      Owner / Technician
      • Sep 2005
      • 4741
      #32
      Originally posted by copytech,mike
      Dont listen to these idiots on here. ADF jamming has nothing to do with resolution. or any settings. Make sure the sensors are clean and try replacing the white drive coupler on the rear side.
      Who the fuck are you to come on this forum and call other long time techs idiots! Just shows that in fact you are the real idiot! If you knew what you are talking about you would know that scan speed does change with scanning vs copying, resolution, settings, etc.
      • rrrohan
        • Sep 2011
        • 1977
        #33
        i must admit i didnt notice speed change in scanning when setting higher res. is that only on older models?
        • allan
          RTFM!!
          • 5462
          #34
          Older machines scanned slower only because it took longer to process the scan data and converting it into the format of your choice. I know that i did have luck finding a problem on a B363 machine. The ADF did feed slower on higher resolutions. Guess processing power has become more affordable or required by the newer machines.
          If I am wrong about something then I would be more than happy to be corrected.
          Whatever
          • tsbservice
            Field tech
            • 8032
            #35
            Nothing wrong even on newest bizhubs.
            DF-714(dual scan DF for bizhub C250i)
            Scan/FAX mode 1-sided (300 dpi) 80 pages/min.
            2-sided (300 dpi) 160 pages/min.
            Scan 1-sided (200 dpi) 100 pages/min.
            2-sided (200 dpi) 200 pages/min.
