Faxing problems Bizhub C360
  • glenbennett
    • May 2015
    • 68
    Hello
    I installed a bizhub C360 I am able to send faxes however I am not able to receive them from other lines. when I call the fax line from my cell it rings busy. Please help
    Thank You
    Thank You,
    Glen Bennett
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Faxing problems Bizhub C360
    plug in a handset and test the line, it sounds like a line issue not the machine.
      • 23007
      Ditto that.
      • glenbennett
        • May 2015
        • 68
        Ditto that.
        I tried the old fax machine they have and it works fine. So I'm stuck maybe the fax board is blown? How do I find out if its blown?
        Thank You,
        Glen Bennett
        • Synaux
          • Mar 2012
          • 1224
          • minimerlin
            • 851
            Did you use the Fax Cable that came with the new machine/card? KM machines can be picky!
            Please do not PM me without asking first.
            • kingarthur
              • 1351
              I have to agree with minimerlin......the amount of times i've seen engineers use the lead from the old fax...cos it's easier....use only the KM fax lead
              • manuelcorrea
                • May 2009
                • 46
                Try doing a fax file format
                • glenbennett
                  • May 2015
                  • 68
                  Thank you for all your help however the machine was set on Japan not USA that was the problem.
                  Thank You,
                  Glen Bennett
                  • glenbennett
                    • May 2015
                    • 68
                    Thank You,
                    Glen Bennett
                    • Synaux
                      • Mar 2012
                      • 1224
                      Thanks for the update and glad to see you got it working : )
