Printer Prints Lines
  • AVNER
    • Aug 2010
    • 11
    I have a photocopier Model C 253. My problem is that the printed page has stright line all over the page, with equal gap between each line of 4 mm. I changed the transfer, calibrated the NVRAM, I made gradation calibration of the machine and nothing helpd, the problem remined the same.
    I attached an example of a printed page.
    Thank you,
    Avner.
    • 23008
    Re: Printer Prints Lines
    Is that really "8" copies, or is that just the effect of dumping the NVRAM?
    They look a little too close together to be the "Lines of Shame", but it might be.
    The short version is that if you skip several of the steps in setting up a new Konica Minolta color copier, the machine will indicate this by making these lines on all your prints and copies. I've seen them in magenta or in cyan, but never black or yellow. It may be a consequence of the NVRAM being dumped.
    What I would do is find a setup checklist, and do every item on that checklist, in that order, to the letter. If it is the Lines of Shame, it will disappear. =^..^=
